Key Fob
Received 4,325 Likes
Just make sure you get one from a '96-'99 model (all 4 buttons are exactly the same size on these) from a US seller. Other countries may use different frequencies and may not work.
Also, have you tried to replace the battery and cleaning the button contacts with alcohol? That often brings them back to life.
If you're thinking about buying a replacement fob from fleaBay, the important details to look for are on the back of your current key fob: frequency and type (my UK fob works on 433 MHz and is type LA2610BA). These must be exactly right for your car, otherwise there is a strong likelihood the replacement will not work. It's worth checking - most sellers will be happy to give you those details in advance.
Getting a new fob to work with your car seems daunting the first time. But it's actually pretty easy if you follow the step-by-step guide in the various 'how to' threads.
Hope this helps.
Best wishes, Colin
Hope this helps.
Best wishes, Colin
My advice if you go the ebay route, use seller remotzforless. I ordered several "good as new" reconditioned guaranteed to work remotes but all three had buttons that didnt work. Or did with major pressing. I found remotezforless's listing and sent them a message with all my numbers on the back and they sent a new on the that worked perfectly. It's brand new not used and I think I paid 53.00. I programmed in 3 minutes! Mine is a 2002.
philwarner
28
07-11-2017 10:21 AM
Jzar
09-27-2015 02:55 PM
