Key Fob - can it be repaired?
A year ago, one Fob worked very weakly, the other not at all. Replaced the CR2016 as per existing and manual, nothing. Been playing with them for a while, remote tester arrived today and neither is transmitting. Is there anyone who can repair these? Radio shops are few and far between these days.
Rex, 2 units no transmit same time? That is too unusual imo.
Look I have to ask, any chance batteries in backwards?
Edit: the 2 batteries are in series. Ensure good contact both sides both batteries, a pencil eraser is perfect.
Got a DVM? What voltage do batteries show?
Got a way to test the RF Tester? FYI if in USA with Comcast cable - their remotes are RF for all CATV transmission.
When you mentioned Aluminum did you mean you bypassed the rubber/carbon to try to activate by placing Al on the printed ckt board?
If yes, I love it but Al is a shitty conductor. Bend a copper wire or better yet, use a stranded Cu wire and try again (speaker wire?).
These remotes are hardy, I once put 1 through a full washing machine cycle (never washed a pair of pants w/o checking pockets again!) - no effect.
For the record both batteries sit face up in the rear panel of the remote facing the back of circuit board.
John
John
Received 1,686 Likes
cycle on. Like you, the remote worked fine afterwards, plus it was really really clean. Even the key didn’t appear to suffer any effects from the ordeal.
I did take the battery out and let the remote dry out for a day before trying it .
Z
Johnken (09-16-2022)
It appeared that the buttons had some sort of conductive material on them to engage a circuit when pushed against the circuit board. Tried putting some aluminum foil under the buttons but had no effect at all. copper foil would be better but I don't believe that is the issue anymore. I really do not know. Key works - that is probably how I will use it, forget about convenience.
Z
Rex (09-16-2022)
Have gone through the programming several times, that is what led me to buying the remote tester. Neither is transmitting. Buy a new one - if I could find one for under $400, I would.
karenh
09-03-2020 03:59 PM
jdmcomp
08-01-2014 01:08 PM
