Keyfob battery(ies)
ALL 20xx (20mm x 1.6mm, 2.5mm, 3.2mm) batteries are 3 VOLTS.
2016=20mm x 1.6mm-3 VOLTS
2025=20mm x 2.5mm-3 VOLTS
2032=20mm x 3.2mm-3 VOLTS
Stacking the batteries (series connection) will provide 6 Volts.
Make sure you install the correct battery(s) for the keyfob transmitter you have.
To >VIN A11050 should require TWO (2) CR2016 batteries. (JLM11905)
From VIN> A11051 should require ONE (1) CR2032 battery. (JLM20930)
I think the VIN and battery combos are correct?
Received 2,400 Likes
The format of the last 6 characters in the VIN changed from 6 digits to 'A' + 5 digits after ....042775, essentially with the introduction of the 2000 MY.
Your VIN of .....028772 precedes the start of the A + 5 digits, hence the fob requires 2 x CR2016 cells as per motorcarman's list in post #3
The following 2 users liked this post by michaelh:
DavidYau (06-23-2020),
motorcarman (06-22-2020)
150FHC
04-08-2020 06:11 AM
