Keyless entry problems
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
I have a 1999 XKR Coupe which I bought 6 months ago. It came with two keyless entry tags. One doesn't work at all, and the other works only when you are very close to the vehicle and sometimes not at all. I have replaced the batteries in both units.
Can anyone tell me where to get new units at an affordable price?
Ocrb
If you are talking about the key fob (remote), you may need to reprogram your fob. Just do a search of key fob programming here on the forums.
If you have cleaned the inside of both your fobs and the programming doesnt work, then you may be facing another problem other then the fob which is the Security Locking Module (i believe thats what its called) located in the trunk under the fuse box next to the battery.
You can check and see if the attenna is connected properly to the module. If all looks connected then you may want to consider purchasing a new one on ebay. They dont run much - I believe $149 tops but depends on what year... hope this helps..
The later fobs with switches often need the switches replaced (they are about a buck on ebay).
You know you might want to try the flip key mod. I've done several of these now (they are kind of fun to do) and you end up with a newer generation key and remote. The parts aren't bad on eBay and all you need are a few tools and time.
https://www.jaguarforums.com/forum/x...ictures-93167/
Wolfy
05-28-2024 08:06 AM
