Knocking, tapping noise on idle-HELP!
Old 08-18-2022, 04:11 PM
TGraves's Avatar
Default Knock
Out of the blue, mine started this at idle, then quit after restart. Hasn't done it since.
Old 08-18-2022, 11:19 PM
Kuddlesworth's Avatar
Weird. I'm no mechanic but is it possible it's the ECU retarding the ignition to such a degree it makes it sound like this?
Old 08-19-2022, 12:59 AM
Pistnbroke's Avatar
Its the chuffing noise in that recording which worries me ...sounds like air ..loose plug or similar .I would get a length of pipe about 2 in dia and 2 ft long to your ear and see if you can isolate it .
Piston slap is sharper like a bad tappet
Old 08-20-2022, 02:53 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Get yourself a stethoscope from an auto parts store and start probing. Stop the guess work.
klauschou (08-20-2022)
OnFire
10-20-2020 04:34 AM
mat32essex
10-12-2020 07:59 AM
daywalker
04-22-2020 02:42 PM
MR. CJ
09-06-2014 08:24 AM
segillum
08-03-2012 08:10 AM
Quick Reply: Knocking, tapping noise on idle-HELP!
