Largest XK8 Wheels and Tires
Guys,
Does someone know the largest wheel and tire combination we can put on the rear of our XK8s? I am currently running black powder coated Asteroids from my old XJR that are 8 inches wide and I want to have the rear wheels widened to allow for the absolute widest wheel and tire combination. I believe later XKRs have 10 inch wide wheels, is that the widest that will fit?
Thanks all
Thanks all
platinummaker (04-25-2013)
The 285/30/20 on the rear of the XKR is the largest stock size. It looks to me that 295 would fit okay, but any larger would be pushing it. The wheel offset is critical in sizes this large and not many folks have the information needed to pick the right wheels when going wider than stock. A problem I have had is that 30 profile tires make the car very tender to drive, as potholes will ruin the rims easliy. I had one of these $2500 wheels ruined by a pothole that all my other cars would pass over with no problem. I find myself leaving the car at home because of this.
Hi Platinummaker.
Here is a picture of what AVos described. These are the Jaguar vortex 20 inch wheels. from the 2010 XKR-S.
front is 9.5 inch wide and the stern is 10.5 inch. The back wheels miss the arch by about a mm. My car, IMHO, looks brilliant, squat and planted. I love the look.
I have seen some custom 22 inch chrome blingers on a US custom car and it looked, oh! so wrong.
These just about work with the adapters.
![Largest XK8 Wheels and Tires-img_0674.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/40702d1480968328t-largest-xk8-wheels-tires-img_0674.jpg)
Best of luck,
Colin.
Best of luck,
Colin.
The following 2 users liked this post by Capt'n Col:
platinummaker (04-25-2013),
User 070620 (05-02-2013)
TreVoRTasmin (08-27-2015)
Received 4,280 Likes
I prefer a non-staggered setup. So that brings up the question: What is the largest tire that will fit on the front?
I am currently running 265/40s on 9x18" rims all around (Jaguar Flutes). Will a larger tire on 10" rims fit the front without scraping on an XK8 lowered about an inch? If so, how wide can the tire go? And what should the offset be? I would like to leave the fender liners in place.
If too big, what is the tire width limit given a 9.5" rim? What offset for these rims? I still prefer 18" diameter rims; larger looks hot but starts getting into issues.
Ian A. McLaren (07-24-2014)
Hi Guys,
Just wanted to check in on my rear wheel/ tire upgrade. Thanks to your input, I went with the stock 18 x8 inch asteroid wheels off my earlier XJR widened to 10 inches. Tires are 285x40x18 Nitto 555's. 295's might barely fit too, but I didn't want to get greedy the first time out as the car is lowered close to 2 inches. It was close, but no rubbing or scraping. I have H&R 1 inch spacers on them as well.
The widening was done by Eric Vaughn Machine in Southern Cal. (No affiliation). He did a great job. Cost $300/wheel.
Thanks again for everyone's continued help.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Hi Platinummaker.
Attachment 40702
Best of luck,
Colin.
Attachment 40702
Best of luck,
Colin.
The new setup looks good...and I think the offset on the rear is perfect. I've been considering pushing my 8.5/9.5 staggered wheels outward a bit with spacers, but since my ride height is nearly stock, it would look silly unless I lowered the rear at least. Just too much work and cost for me at the moment, but perhaps a project down the road.
Hi Guys,
That's very interesting. For original R20 BBS Paris rims I would like to go 255/40R20 (9J) front and 295/35R20 (10J) rear - my car (XKR 2002) isn't lowered yet, nevertheless - does front tires in that size rub anything inside of arches, or not? From my research, although front arches are big enough, there is very little of free space, especially when wheels are turned out. I'm about to buy new tires, kindly advise from your experience.
Thank you in advance,
Vadim
