Leak-down test 20-25%
Hey everyone. I just bought a 97 Xk8 w/75k miles. I had a leak-down test on it and the readings were 20-25%. Is this normal for the xk8? How long do you think that engine will last? Another 25k maybe?
I am about to spend $2,400 on tensioners + water pump + tstat etc. Should I just drive it until the tensioners give and do a rebuilt at that time?
Thank you,
Gene
Thank you,
Gene
NO! These engines are not rebuildable as far as I understand, and if they fail more then likely it will destroy the engine, fix those tensioners. If the compression is still good on it then it should go a long way if you maintain it. Standard procedure for our vintage of motor is to change these issues (tensioners, water pump, thermostat riser) to the updated/better parts and then loving maintain the car. By the way, you will LOVE driving the car once you get to really enjoy it, only problem I have with my 99 is the pain it causes in my cheeks, can't get rid of that grin..........
