Left headlight mounting bracket - 1999 XK8
Good afternoon,
I recently purchased a 1999 XK8 convertible (signature pic) and I have found several items that need attention. One I am including in this post is the 'mounting bracket' for the left front headlight assembly. I am including the pics for the right side assembly identifying the part but I have no way to try to find it. Any "parts" help would definitely be appreciated.
This is my first Jaguar and I have extremely little knowledge of Jaguars. I am in Southeast Texas (Beaumont). I will post future items that I need assistance with. Thanks in advance.
Received 4,339 Likes
Wes - info posted below. SNG Barratt's has a great site you can use to find part number info - then search for cheapest part. SNG, jagbits and Coventry West are forum sponsors and not sure about Coventry but SNG & jagbits offer a 10% discount to forum members https://www.sngbarratt.com/us/#!/Eng...20~2F%20XKR/11
Headlamp Mounting Bracket
$40.91
Product Code:
LJA4660AE
Part Type:
Standard
Stock Status
Special Order Goods - Estimated lead time 5 - 7 days
$40.91
Product Code:
LJA4660AE
Part Type:
Standard
Stock Status
First...thanks to each of you for replying so quickly!
David, if the bracket is a 'locating mount', what holds the headlight assemble in place. The assembly had been 'pushed backwards in a "minor bumper" mishap, so I was told which broke this particular bracket. When I took the assembly out, there were no other points that it is attached to the frame/cavity. Now I am more than curious to see the right side and understand what holds the assembly in place.
Steve, Thanks for the parts site. I am sure I will be using it.
Fixings for the XK8 Headlamp Lense
The main headlamp fixing is a T40 bolt on the bottom of the unit which should prevent any forward/back movement. There's a top T30 outboard securing screw and the inboard side screw, you know about, which control the lateral side to side alignment.
Check out the pics in the attached "How To" Guide for replacing a headlamp lens on a XK8 - courtesy of DCR Autoparts. Dave R, in the UK, is my go to guy for my weird parts requests - one of which was to change out the front half of the head lamp unit.
Good luck and let us know how you get on.
Johnken (08-24-2019)
Wow! This will be a great document to help me. It appears I have a bigger problem than I thought as the whole assembly was completely loose in the cavity, likely all the securing points were broken in whatever mishap occurred.
When I removed it the only 'obstructions' to getting the whole assembly out was to remove the connection plug for the electronics..... I did not have to get under the front end or remove any other bolts/screws. I have a bit of work to do to replace..... Appreciate your input. I will work on it and give an update...
Realjwc,
Considering the difficulties in access for the T40 bottom bolt, I would not be surprised if a Previous Owner (PO) just gave up on the T40 bolt, and hence the situation you find yourself in. As the PDF document says, an adjustment levering bracket to help align the T40. Maybe the PO didn't know that.
On the other hand, the plastic bits in our car are 20 years old, and I also wouldn't be surprised if the headlamp's bottom plastic base's receiving thread had broken in a previous incident. It's a significant T40 size bolt that fixes the car to the plastic headlamp unit.
Good luck and report back with whatever you find. Where's there's a will, there's a way. ....... Plus you may need some spare cash for parts.
thanks..... but how do I know if mine has headlamp washers? I have the assembly out and am repairing the top bracket where T30 goes but still have to manufacture the "locating mount" attachment. Since I am not into making this one original condition, just a sound ride, I will figure out how to make the attachment. Looking at it when I got the pieces out, I am not sure how it would even go back in...very easily.
Thanks!
Thanks!
Headlamp powerwash unit
Realjwc,
Youtube link below for demonstration of the headlamp power wash
This shows the triangular mirror piece Sklimii referred to.
Here's a couple of pictures of the headlamp dis-assembled showing the power wash unit (circled in red) - that's if you have it.
If you have it - the powerwash unit has a triangular plastic flange that clips into the bottom of the plastic headlamp unit. If the previous owner has taken it out, it should have been disabled at the pump, otherwise every 6th time, the windscreen wiper washers are used, there'll be a squirt of water somewhere.
I haven't been able to work on the headlight but is in the plan this week. I am planning on replacing the T40 bolt as it appears that is the main one to secure the assembly in place, my only problem is finding the replacement bolt. I assume (yikes) that a torx bolt the same size would work if I can come up with one as I have not found an outlet for the actual Jaguar torx bolt except one site from overseas for a $2 bolt.
DavidYau (06-26-2019)
Thank you Frank........ The two places where the assembly attaches are both in need of repair and I am going to try to repair them (epoxy) and see if they will hold with bolts. I went ahead and purchased the correct plastic bracket shown in the right assembly picture above but am concerned that the age and brittleness of the assembly will just break. I hope epoxy repair will work thoroughly and I won't have to install the bottom T40.
Appreciate the input from those of you who have experience, I'll post the final assembly.
Cheers!
Wes
Cheers!
Wes
Nicely done
Cheers!
Wes
Cheers!
Wes
iramphal
02-22-2018 08:57 PM
99xk8
12-14-2012 08:55 PM
ashmorem
08-18-2009 09:36 PM
paulrez
12-16-2007 09:26 AM
