LHD Headlights
#62
Dreal
Hi Guys,
The visit to the DREAL was not totally satisfactory, the car failed! Two items did not meet the requirements. 1 - the warning light on the rear fog lamp switch failed to light. 2 - the four marker lights on the bumpers are illegal in France.
1 - is the bulb in the switch replaceable? how is the switch removed?
2 - does anyone with an XK8 in France have this problem? the tester has asked that I paint over the marker lights the same as the body colour.
These faults are so important that I need to send some photographs once the problems are addressed.
I want to keep the marker lights so I am proposing ro kut some modellers plastic sheeting to fit the cut outs and spray them to match the bumpers and then when i have the Carte Gris replace the marker lights.
maybe i should have taken a bottle of wine after all.
Regards
Regards
#63
Matthew,
They're certainly making you jump through hoops with this.
1. the Console Switch Module has replaceable bulbs. Dealer gave me them by mistake when I needed the larger Instrument Pack bulbs.
Part Numbers
LNA5180BA - clear
LNA5180CA - blue
2. the tester will accept photo evidence of the painted markers and doesn't want to inspect the car again? Photoshop!
Part Numbers
LNA5180BA - clear
LNA5180CA - blue
LHD Headlights
Hi,
Update on the DREAL, the Attestation arrived yesterday, yippee!!! So it is down to the Prefecture in Sarlat early Monday morning armed with all the documents so I should have the Carte Gris within a couple of weeks. Unfortunately i am going back to London for a month, someone needs my services there, more work I think, but I have a Jaguar Driving Day next Saturday.
Does anyone know where the Cobra alarm is located on a 1998 car? Cobra have been helpful with some information and will be able to help me reset the alarm, all I have to do is find the thing so that I can get the model number.
Hope someone can help.
Regards
Matthew
Regards
Matthew
#69
Hi Matthew,
I havfe just put my 1997 XK8 through French CT yesterday using the deflectors from Black country Jags and it passed with no problem, just need to make sure your lamps are realigned before you have the test Probably good idea to have a garage do this.
I paid UKP80 for the deflectors and they take around 20 mins to fit, and come with instructions. I'm off to the prefecture on Wednesday to complete the change to French plates
Richard
Richard
#70
LHD Headlights
Hi Richard,
Good luck with the Prefecture and remember - no copies, all documents must be originals or you will be sent packing.
I have just come back from the Prefecture with a temporary Carte Gris but because there were two different CV 23 & 21 they could not tell me what the cost would be when I last applied it was €406 so I am hoping iy will be about the same and remember as your car is like mine over ten years old, the cost is reduced by 50%.
I fitted LHD headlamps which I got from a subscriber in Belgium €280 inc PP.
Regards
Matthew
Regards
Matthew
#71
#73
Hi Richard,
That is good news and I agree the process is essentially straightforward provided you follow the rules and never present copies. My problem was that the car was a US car and I could not get a full CoC from Jaguar hence the DREAL. I now have the document from the DREAL and all the papers are with the Prefecture. Hopefully when I get back to France in a few weeks the Carte Gris will be waiting. Where are you based in France?
Regards
Matthew
Regards
Matthew
#76
#78
Hi,
At last, I have a French Registration. I visited the Prefecture in Perigueux last Friday and within thirty minutes had the appropriate paperwork and ten minutes later had number plates. And the cost? €384.5!
Thanks for all the helpful suggestions and advice.
Regards
Regards
It's been a long and difficult journey.
I don't suppose you're considering a newer model XK8 just yet?
