Is this a lifter or a coil pack?
I have been trying to figure out the cause for this sound for a few months now. Hoping it's not the Timing chain tensioners. My dad, that is a mechanic, says that it may be a lifter. I think it may be a coil pack. I saw a video of a GM motor with a VERY similar ticking/tapping sound, and it was a plug wire that was not on the coil. I know that it's a little different for the XK8, where it is a coil pack. If it is a coil pack issue, I cant take it off without a bolt extractor, that I haven't purchased yet. A previous owner/mechanic rounded out the bolts on most of the coil pack bolts, so I'm going to need a full set of new bolts. I found these when I tried to change my own sparkplugs. Couldn't even do that lol.
RichardS (04-23-2024)
More research. Jag has a tool, hard to find, about $300US, that will depress a valve so that you can remove and replace shims. Then you use a long feeler gauge to check. It's that or pull off the camshaft and re-rime the engine, I suppose.
I tried 5W-40 oil, and some Liqui-Moly Viscoplus. Didn't help a bit.
So, I guess I'll just live with it. Engine performance doesn't see to be affected at all.
Mine makes the exact same noise. After sleuthing I found it seems to be coming from cylinder 8. It sounds for all the world like a lifter tick. We thought perhaps it was an exhaust manifold leak so I disassembled the exhaust and did a smoke test up the left cat. Nothing. More research. This engine uses the infernal micro-shims for valve lifter adjustment. The genius mechanic who was employed by the previous owner replaced the heads and I strongly suspect he didn't quite get the shim stack correct on that one cylinder. Don't know if it's exhaust or intake.
If you decide to re-shim, it's not difficult to unbolt the camshaft and move it to one side to access the buckets. Just put a couple of cable ties around the chain and sprocket and lock then together to ensure that you cannot lose the valve timing.
Richard
Y2KJag (04-24-2024)
Y2KJag (04-28-2024)
Replace the timing chains and tensioners. This should quell any "hazardous" noise. I would also replace the coil packs. This will narrow down any noses to the other source(s). If you still hear the noise, take it to a qualified mechanic for an appropriate diagnosis.
Y2KJag (04-28-2024)
Just bought a 2001 XKR the other day that sounds exactly like this! Has been sitting several years so my first move is to change the oil (which is dirty) with Castrol 5-40w or 10-40w. I also plan on putting in new ignition coils and spark plugs. At the moment it still sounds like a diesel truck
