Lincoln LS Parts Interchange
Old 04-10-2011, 09:19 PM
Spurlee's Avatar
Default Lincoln LS Parts Interchange
I understand that some/many Lincoln LS engine parts interchange with the XK8.
I have a MY2000 XK8. Is there anything more to know than just asking the parts counter guy to reference a MY2000 Lincoln LS with a 4.0L and comparing the parts?
Old 04-11-2011, 07:24 AM
K.Westra's Avatar
Well the Lincoln LS engine is a 3.9 I know the tensioners are the same, but the block, crank, rods, and pistons are different. That is the extent of my knowledge.
Old 04-11-2011, 07:03 PM
Beav's Avatar
I think we should have a sticky listing parts found to be interchangeable with the LS. It could potentially save each of us some money.
Old 04-11-2011, 07:41 PM
07XKJaguar's Avatar
Found out by chance that the thermostat is the same. Went to the Ford dealer since I was in a bind having to order one, and he even showed it crossing over. Was on a 97 XK8.
Old 04-11-2011, 08:48 PM
plums's Avatar
Received 2,184 Likes on 1,624 Posts
Cheaper from Ford?
Old 04-11-2011, 09:28 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
Cheaper than Ford?
Gotta be!
Old 08-15-2016, 08:52 AM
K.L. Champ's Avatar
Default Lincoln ls
I have a question if anybody know if the s type jaguar dccv is compatible with lincoln ls? interchangeable part number XR822975
Old 08-15-2016, 09:10 PM
auburn2's Avatar
I don't think the block is any different.
Old 08-16-2016, 01:03 AM
JagV8's Avatar
Received 4,538 Likes on 3,947 Posts
Try Motorcraft YG-355
Old 06-09-2019, 09:59 PM
Anyone know if the MAF sensor is interchangeable with the Lincoln LS?
Old 07-01-2019, 09:04 AM
Default A/C control relay
Just wanted to let everyone know, the relay for the 2003 Jaguar S-Type 3.0 is the same for the 2003 Lincoln LS. O had to replace this and the auto store did not carry the Jaguar part so I told them to look up the relay under the LS. Perfect match!
Old 08-29-2019, 03:04 AM
Mike Lore's Avatar
97 Xk8 uses the same valve cover gaskets,they were less than half of Jaguar OEM.
Timeisrelative (08-29-2019)
Scott B
10-24-2015 01:29 PM
convincor
09-10-2015 06:50 AM
jaggermang
09-08-2015 07:07 PM
DAN L
09-08-2015 07:21 AM
1100me
09-07-2015 06:26 AM
Quick Reply: Lincoln LS Parts Interchange
