List of Performance Improvements
For this thread please list any performance improvements for the XK8.
How to Post in this thread:
What not to put in the thread:
Example:
4.0L: Changing the spark plugs from the original gap of .044 to .052. I used the NKG PFR5G-13E. This improvement is at the advice of a Jag TSB. It is hard for me to tell if it is the new gap or just new spark plugs but the car absolutely is smoother after the change. Detailed Thread.
- Give a description of the improvement and the effect of that improvement.
- If available, link to a more detailed thread on that improvement.
- The only reason to post on an already listed improvement is to correct wrong information.
- If this improvement is specific to a car year or engine type, list that.
- Modifications that avoid issues, but do not improve performance. For example, decreasing the voltage for the hydraulic fluid pump to avoid a green shower.
- Repairs to bring up factory specs. For example, putting in new OEM shock mounts.
- For improvement is listed, do not add more posts on that improvement type.
Example:
The following 3 users liked this post by RJ237:
This is a good idea but the subjectivity of 'performance' may vary, ie smoother running vs dyno test HP. ex; spark plugs, was it the gap or new ones?
02 XKR
Bosch High output Inter-cooler Pump
Provides higher through put of the inter-cooler loop from stock pump which should lead to better performance and longevity of the IC.
02 XKR
Any handling improvement is likely to be subjective as you would need track times for before and after to show a real benefit.
For BHP performance improvements, ideally before and after dyno plots should be shown or before and after MAF peak readings at a push.
Subjective comments are close to pointless, as I've noticed that my car feels faster after I wash it.
The following 2 users liked this post by XKRacer:
Gregfromuk (11-17-2014),
RJ237 (11-15-2014)
Aus V8S
11-13-2015 11:01 AM
jagent
09-12-2015 09:10 AM
