Little help with the gauge modification kit
Hi all, I'm installing my gauge kit from jagwrangler today and have hit a small problem. The right side harness calls to tap into a Pink/yellow wire. According to the JTIS for a 98 that would be a KY color code. The JTIS doesn't show that code for the right side connector. There is a purple/yellow on pin 3. Can anyone tell me which pin they used for the pink/yellow wire? Thanks
I'll get that corrected going forward. Thanks for pointing this out.
itspec60 (06-24-2012)
