Location of Cabin/Pollen filter
Received 2,190 Likes
BELOW THE WIPER COWL, REMOVE THE WIPERS AND COWL, LOOK DEAD CENTER BELOW ON THE FIREWALL.
YOU SEE AN EMPTY SPACE AND A COUPLE OF STUDS, THOSE ARE TO ATTACH THE FILTER BOX AND FILTER, CAUSE i HAVE NEVER SEEN A US CAR WITH 1 FITTEED FROM THE FACTORY. THEYRE INSTALLED BY CUSTOMERS OR CUSTOMER REQUEST
description_______________________ #_________________ part no________ pic______ # ______MSRP
cabin air filter _____________________1_____________ MJA6863AA______ 1 N 07____ 2______ $73.00
filter housing _____________________1 _____Part number MJA6865AA was
superseded by part number MJD6865AA. ______________________1 N 07____ 1 ______$30.80
screws_________________________ 2 ______________JHG10625E ______1 N 07 ____3 _______$2.00
water shield _____________________1 ______________MJA6858AA______ 1N 07_____NL_____ $20.50
Try http://www.trademotion.com/partlocat...&siteid=214626
As you've landed on an eight year old thread with this question, it should be an indication of the value of pollen filters on the XK8! Rarely fitted and often soaked with water owing to the location, they are useless. If your XK8 is fitted with a pollen filter, throwing it away will help freshen the air. If not, then an AC cleaner should do the trick.
OK, someone on subject of X-308 cabin pollen/air filter posted link to
Your search - jaguar Tech Service Bulletin TSB 412-09 - did not match any image results.
But, I got "did not match any image results." as noted above.
Somewhere on the "net," I watched a You-tube video of an (04) Red XJR owner replace his Cabin Filter in about 5 mins (it was under glove box, (RH side), pulled down a soft panel, removed 2 plastic fasteners, and there it was). Now "consensus" seems to be that Cabin Filter(s) in X-308 ('97-03) is a "special (rare) order" item. That would explain why I get varied shapes/numbers Part# for "Jaguar XJR 2003 Cabin Air Filter. One post (above) gave Jag's TSB number to explain this, but...well, you can see search result.
Anyone have some sort of "definitive" solution to this apparent "mystery?"
THANKS in advance.
'03 XJR ...15B83MF50806
Aiken, SC (2nd of 2 US owners)
THANKS in advance.
aholbro1
08-05-2021 05:02 AM
axr383
09-18-2015 11:19 AM
chatmanx
09-11-2015 07:17 PM
