location of VVT solenoid on 2000 Jaghuar XK8
Do not start the engine. Pull the cam covers off and check the secondary tennsioners and timing chain. If it is the tennsioners and it only jumped one tooth you can save the engine. If it jumps two teeth the valves will hit the pistons.
The pictures below are from a car I bought that the local shop keep on cranking the engine trying to diagnose the problem until it jumped the second tooth and you can see the results. I put a new head, piston, and rod bearings to repair the damage.
I had an after thought.
I see you from my area and new to the forum.
How long have you had the car and some history.
Did the car ever overheat? If it overheated dropped valve seats will make a sound that you might think it was starving for oil.
I know of a car in our area that overheated and hope your car isn't it.
Rob Reilly
04-12-2018 05:58 PM
