Locked Keys in Boot and Battery is disconnected..!!!
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
HELP..!!!! I have locked the Keys in my trunk and I am at a loss as how to get the trunk open..????? Any ideas..? I have no SPARE...the battery is disconnected and I cannot access the trunk from the rear seat.
Any help appreciated....
If you have access to the cabin. Open the bonnet and on the drivers side you will find a terminal that you can hook jumper cables or a battery to. It is a positive only and you can ground anywhere, then try to release the boot with the interior button. Be careful and watch for cables getting hot which would indicate battery cables in the boot are grounded.
scottatl (09-07-2019)
Can you tell me where to find this terminal..? I don't see anything on the drivers side..? Please and thanks
Open hood.
Stand on drivers side (USA)
See shock absorber (black plastic cap in center, 3 shock bolts each covered in black plastic) by your belt buckle. We will use this to find the 12volt terminal.
Dead reckoning:
Touch shock bolt closest to engine. Now move hand back toward you and left to next shock bolt.
Move hand left about 2 inches towards front of car.
In a few inches see black rectangular fuse box (black plastic rectangle cover)
Move hand over this box, move toward edge closest to engine.
Right rear Corner of that edge = see black flexible rubber cap. It covers the 12volt battery terminal.
Remove cap, silver bolt is battery.
Ok to connect 12v here. Will give you power to press trunk release button. Charger is OK. BUT: NEVER TRY TO START THE CAR FROM THIS TERMINAL. You'll blow the 50amp fuse. Remember Vern's note about hot cables (above).
John
Dead reckoning:
John
The following 2 users liked this post by DavidYau:
Johnken (09-24-2019),
Timeisrelative (09-08-2019)
Johnken (09-07-2019)
Well...YOU were correct sir..!!!! I tried again and moved the ground around until I found a good spot...and it worked fantastically....THANKS TO YOU ALL..!!!
Congrats on opening the trunk. Now get another key made. Lots of info in this Forum on sources to get a blank Tibbe cut relatively inexpensively.
I too only had one master key, so trimmed the tip of my green valet key to become a spare driver key ... and I’ve used it a few times to open the trunk when I stupidly closed the car door with battery disconnected and key inside.
Open hood.
Dead reckoning:
John
Dead reckoning:
John
On an S-Type R6 2001
I was able to inject 12V inside the car,
But unfortunately it did not work because of the alarm that is alware eanble.
So electrically I have light inside the car, can open the gas tank access hatch
but no way to release the boot with the interior button.
please help
I am blocked in the bush
Regards
Looks like you were trying to type always enabled. Heres the problem, you've got an S type not an XK8. I am not sure of the difference with that model.
Maybe you'll get faster answers in the S type forum?
If you go there say these things:
Alarm type ( factory or aftermarket)
Whether you can turn alarm off with key in door (we can on xk8)
How it is that the alarm has power if the trunk open button doesn't
Oops, I just realized my key in door question is a dumb one - keys are in trunk! Laughs on me there...
How did alarm turn on if keys are in trunk?(might as well address it)
Hope this helps
John
Hope this helps
John
haggis95
01-21-2011 06:08 PM
