Locking car with top down
Would it be normal to go off if someone tried to tamper with it somehow or put their hand inside?
Does it have motion sensors?
I just bought a 2004 Landrover Discovery HSE with an alarm system that worked.
On a hot windy day , I left the windows down , juts a smidge and came back at the end of the day to the alarm going off. I think due to the motion sensor inside?
FYI, Top down alarm on - the trunk open button is disabled, pressing it does not set off the alarm. I just tested mine a short while ago when my valet swtich was not working.
Strangely enough when my car is locked (alarm on or off doesn't matter), any tries to open the driver's door from the outside puts it in Deadlock mode - Can't open the door from inside or outside and I have to go through one or two cycles of using the key in the door to unlock it.
I thought using the key to lock the door from the outside will always arm the alarm. If so, you might have to reach in and press the door handles to lock the doors.
To the author, mind if I ask why you specify "Top down"? Besides being able to reach in and press the handle to lock I'm not sure what that has to do with this.
So far I have not found a way other than remove fuse or wiring to disconnect my alarm when locking car. Top down, windows down, valet for trunk security set , I lock door with key. all good. Id rather have my alarm set with the top down. I cannot answer why your alarm would go off... Rich B
WTB[Canada]: Jaguar Car Cover for XJ6 XJR 95-97
snowball
02-29-2016 07:33 PM
WTB[Canada]: Jaguar Car Cover XJ6
snowball
02-29-2016 07:29 PM
