Locking issues and windows
I have had intermittent cycling of the central locking for a couple of years now, it usually sorts itself out after a while and operates perfectly. However, the issue returned a couple of weeks ago, then two days ago the remote central locking packed up and the drivers door window did not drop when opening the door, although if dropped manually, it would go back up when the door was closed. I assumed that all the problems pointed to a faulty microswitch in the door latch, so I removed the latch and tested each switch, and found that they were all working properly. The battery (in good condition) was disconnected while I did this, so I knew I would have to reset the windows.
With everything back together, I reset the passenger window, then turned my attention to the driver's side. The driver's side switch did not work, so I tried the passenger switch (on the master switch) and down went the driver's window, but it would not come back up again. Although I had done nothing to the switch except unplug it to remove the door trim, I took it apart to check for short circuits, but all was well (although I could do with a new rocker switch). I could hear clicking from the door control module, so removed that to check for dodgy wiring, but all was well. I also noticed that my door mirror adjustment was not working. In desperation, I tried another hard reset, after which everything worked as it should. However, the central locking cycling is still there.
Although everything is now working, I am perplexed by what happened and wonder whether the problem lays with the door control unit? Has anyone experienced anything similar?
Are you saying that when you lock the car it will lock then unlock? This could be a problem with one of the micro switches in the door latch that is telling you the system is seeing an abnormal status. This could be a simple switch adjustment or just lubrication. First try spraying a little WD40 in the door latches and work the doors open then closed a few times first. This process has worked for others.
I've just been out to test it as I don't usually use the key, so don't know whether it does the unlocking/locking cycle with the key. When I used the key, it unlocked in a single action, however, when I locked it with the key again, the central locking failed to work and it wouldn't lock with the remote (although the remote still set the alarm). I locked and unlocked it a couple of times with the key, then it started its locking/unlocking cycle again and the central locking and remote worked as normal.
Just a hiccup!
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
