Loctite Form-A-Thread, does it work?
I have a bad bolt hole on my oil pan that is leaking and need to repair it My car is a convertible and the damage is right under the cross bracing. If the loctite works then it would be a easy job. The torque for the bolt is only around 9 PSI so it seems it could work. Has anyone had experience with this product?
I have not. I would tap either with a cleaning tap or drill one size up and tap then using the appropriate bolt for that hole.
The following 3 users liked this post by giandanielxk8:
The following 4 users liked this post by TGraves:
Sound advice, except
Unfortunately I do have a small leak coming from that spot. I figured with the next oil change to drop the pan and fix it. The complication is that with the convertible frame cross member is in the way to drill it. I do have room for a thread chaser and will try that first.
Just remove the x-brace. It’s only a few bolts.
The following 2 users liked this post by giandanielxk8:
David Dougherty (01-16-2023),
zray (01-16-2023)
Received 1,686 Likes
that’s what I was thinking too. But my car is a coupe, so not qualified to give a firsthand knowledgeable answer.
just taking the pan off and installing a
heli-coil or time-sert would not take much time once you have all the parts and tools assembled. That’s the way to repair without having to do over.
Z
Z
The following 2 users liked this post by zray:
giandanielxk8 (01-17-2023),
Nickel (01-17-2023)
mpasiuk
20
12-22-2021 10:15 AM
Jon89
07-31-2014 10:39 AM
