long list of codes..HELP!!!
well i took the tb plugs loose and plugged them back in,no cleaning or anything yet...did another reset and warmed the car up...drove it around house few times and acout 1/2 mi. up the street..tranmission fault and restricted perf are gone for now..car still not running completely smooth..will rechecked the codes tom to see if any of those changed or disappeared...
Cleaning and making sure they are clean and tight is important. Do you know if the connectors were ever replaced? I asked earlier about the codes because I recently experienced a P1121 code with a host of many faults. This may be worth reading Jaguar XK8 Throttle Body R&R
i really dont know if they have been replaced..looks like the throttle body has some carbon build up..this could be causing the butterfly to not close properly..maybe causing the rough idle and throwing the p0121 code?can i clean this with carb cleaner?
This is what you need to clean the throttle body Search results for "05078" | CRC Industries When was the last time the plugs were replaced? The car sat for 8 months, try cleaning the TB and then add BG 44K and if it does not clear it up look at the plugs and if that fails let us know. With no codes now it is hard to say.
ok..cleaned TB plugs and TB itself..reset the computer and all seems well..no trans fault no restricted perf and seems to be running smoother..still a little rough at idle..warmed it up to operating temp and drove it 3-5 mi.havent checked the codes..will do that again monday..i got long toes i will keep them crossed..
#28
#30
#31
the trans fault and restricted perf warnings continue to appear randomly...most of the time they disappear if i turn the car on then back on..sometimes i have to do reset..where are transmission electrical connections?i doubt they are visible from the engine bay..do i need to jack car up to find them and where?thanks
#32
#33
#34
This PDF states that it's for the 2003 MY. Can it be used for prior years? Or should I be looking for the same thing for the 1997 MY. Thanks in advance!
#35
I think that most of the codes are probably the same, although the later years may have a few additional codes that the earlier cars don't have.
In any case, I've also got a 1997, and I've attached the diagnostic code manuals below, for both the engine and transmission management systems.
A little light reading...enjoy!
BillyRay59 (01-28-2012)
1964Daimler
09-09-2015 11:28 AM
