Long Term Sluggish Response Problem Solved
Old 02-28-2019, 05:11 PM
CorStevens's Avatar
Originally Posted by bcprice36
Well! OK.....but what is the Denso part Number for a 2005 XKR?
Bill Clyde
if it is anything like my XK8, it should be printed on the top of the sensor or in raised font molded into the plastic.
Old 02-28-2019, 06:37 PM
bcprice36's Avatar
WhiteHat…...You are correct, It was replaced a couple years ago and I hadn't looked that close as I figured they had replaced it with an off Brand....But it is a Denso....I'll copy down the number tomorrow, after I get it out of the Garage.....It's up against the Wall and I could just barely make out the Denso label and it looks like it has 2 or 3 rows of numbers on it..... I replaced the Fuel Pressure Sensor about 6 months ago but I don't think Denso makes those, Mine is a Moss-Europe made in the UK....
Looks like I'm OK with the Denso MAF....but I guess they can get dirty too.....
Where do you park all those Cars in NYC?
Billy Clyde in Houston
Old 02-28-2019, 06:42 PM
CorStevens's Avatar
contact Denso with those part numbers and inquire as to which other manufacturers used the same unit. you might be able to order it by part number directly through their distributors. however, it is probably cheaper through a dealer or parts store. we will then have solved the XKR MAF replacement issue.
PMKimpton
08-03-2019 08:22 PM
Raul Lara
09-14-2015 07:31 PM
KarimPA
09-03-2015 07:32 PM
Raul Lara
09-02-2015 05:23 PM
OkieTim
09-02-2015 12:48 PM
Quick Reply: Long Term Sluggish Response Problem Solved
