Looking for 18" 2005 XK8 wheels
Hi All.... I've been looking on the internet for 18" replacement wheels for 19" Atlas wheels on my 2005 Jag XK8. (The 19's in front have been damaged several times, and repaired, due to the many miserable pot holes around here in NorCal. I don't want to fix them again. I have had no troubles with 18's on my other car. And no problems with my former S type wheels.)
I do like the Jag Hydra wheels, but I've only found refurbished wheels available and that doesn't sound like a good idea with my mind set at this time. New ones are probably not priced in my neighborhood.....
Does anyone know of some dealers that may have nice wheels that will fit my beautiful Cat.....?? I'm looking at Coventry Whitley's as a possibility since a thread I was able to find showed some Jag owners that were using them and satisfied. Following are the specs I found on the internet:
Bolt Pattern: 5 x 4.75 (120.7)
Bolt Pattern: 5x120.65 |
Center Bore: 73.9 |
Hardware:1/2 Lug |
Offset: Front: 15-30mm, Rear: 20-25mm
Size: 18" x 8" FRONT (8.5 is also possible)
Size: 18" x 9" REAR (9.5 is also possible)
Thanks.... help is appreciated.......
Center Bore: 73.9 |
Hardware:1/2 Lug |
Try these guys. I just bought one for $217 shipped. Looks like they have plenty more. OEM Wheels 2005 JAGUAR XK8 | Stock Factory Rims | Alloy Steel
rwm21xk8 (04-24-2013)
KarimPA
09-12-2015 08:15 AM
metalmarty
09-11-2015 07:05 AM
KarimPA
09-03-2015 07:32 PM
