Loose passenger side exterior mirror
Old 06-13-2011, 09:09 PM
billrus's Avatar
Default Loose passenger side exterior mirror
I have an exterior passenger side mirror that is getting loose. How do I tighten it...do I have to take the door panel off or is there an easier way?
Thanks....
Old 06-13-2011, 09:33 PM
WhiteXKR's Avatar
Received 2,988 Likes on 2,125 Posts
Do you mean the whole mirror assembly?
If so, just pull the triangular shaped speaker grill straight out towards you. There is a T40 bolt behind it which holds on the mirror assembly.
Calahonda (09-19-2014)
Old 06-13-2011, 11:28 PM
Andy94SC's Avatar
On my car the mirror was loose, but that T-40 bolt was tight. I saw the washer under the bolt head was kind of bent / stretched concave, so I removed the bolt, and flipped the washer, then it tightened up nicely.
Old 06-23-2011, 04:11 PM
billrus's Avatar
Thanks for the direction about removing the small speaker. The T bolt was loose. Easy fix.
Thanks!!!!!
02jagstype
23
10-23-2022 07:03 PM
kevinl
10-31-2019 06:15 PM
Dicque
09-19-2015 12:53 PM
avern1
09-08-2015 06:25 PM
joey g
US Northeast
09-07-2015 06:28 PM
Quick Reply: Loose passenger side exterior mirror
