Low Coolant Light
I'm going to make a guess that the expansion tank you fitted was the aftermarket one, possibly from SNG Barratt? Rather than me explain, have a read of: https://www.jaguarforums.com/forum/x...cement-212844/
Followup
once again you guys are right on. It’s the brand new reservoir/tank that’s at fault. The magnet is either stuck, dislodged or non existent. When the electrical expert took a magnet to the sensor it worked perfectly. The $75 electrical diagnostics saved me from an expensive ECM repair or replacement that wouldn’t have solved the problem. Thanks Guys
05-03-2023 08:44 AM
Bills
03-30-2022 08:02 AM
philhef
07-12-2014 01:49 PM
svldvc
02-12-2011 01:46 AM
