Low Coolant Light wont turn off
My 2001 XKR is starting to exhibit some senior citizen aches and pains. At 16 years old with only 99k on the odometer small problems are popping up.
The latest is my "low coolant light" Light has been intermittent for months now. Car stated running hot so brought it in to mechanic. The coolant reservoir never was low in coolant, turned out the overheating was caused by a bad thermostat.
Issue now is the coolant light will not go out. Mechanic said the overheating fried it. He replaced the sensor but that did not work. After some research he said the entire reservoir needs to be replaced to fix it.
I would prefer not to replace the reservoir since it works fine. Is there a way of turning the warning message off. Unplugging the sensor does not do it. I always check my fluids so I really dont need to message.
Gary
2001 XKR Convertible
Gary
I have a 1999 XK8 and I had a hard time keeping the low coolant light off. It seemed like I couldn't add more than a table spoon of coolant at a time.The reservoir is always full as is the thermostat housing...or so I thought. I finally figured it out. I do not know about your year, but mine has an upper radiator hose that will "go flat" when the engine is cool, so it has a limited or no coolant in the hose. Try this- Take your thermostat cap off AND take off the reservoir cap. Put the coolant, with the engine off, into the thermostat housing and gently squeeze/release the upper radiator hose until you can't put any more in. Then replace both caps. I did this and my low coolant light has stayed off for a couple months now.
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Received 2,193 Likes
Ok Brutal. I certainly am not an authority on electronics.
My thinking is the sensor is an either open or closed circuit to trigger that light.
I would not advocate bypassing the sensor, but I feel the light on is quite unnerving.
I obsessed over getting it off. I feel many of us Jaguar owners are ocd to some degree, and in a good way. My girl is OCD and it has it's good merits at times, until you're trying to find something that was "put away".
I have had hundreds of mechanics over the years. Many have been correct, many many more have been wrong.
I never recommend not having a functioning level light cause you have no warning of coolant loss and temp sensors don't read air. They read liquid.
the sensor reads the magnetic imbedded in the float as it goes up and down in the reservoir. Its usually never the sensor but a float stuck or bad and sinks to the floor
The sensor is easy to test with a magnet. Pull the sensor out, stick a magnet to it and the light should go out.
There is a little magnet imbedded in the float that can fall into the tank. Fish around the tank with a screw driver to see if the magnet sticks to it. If it does, get a new tank... unless your hobby is building ships in bottles.
Johnken (02-22-2017)
