Lower Ball joint 2000 xk8
The following 6 users liked this post by Mjs128:
Johnken (09-17-2017),
michaelh (02-22-2021),
motorcarman (09-17-2017),
phtohle (09-17-2017),
rothwell (09-17-2017),
and 1 others liked this post.
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1120x2000/20170918_073511_resized_46670dbe750ce84dcc65e658dfd5da69531efa9c.jpg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1120x2000/20170918_073535_1505686600870_resized_45b4e4e470709066f2f076f99dd40d334edf2a7d.jpg)
Looks rough but this jig did the job fine.
I pressed the old ones out on my shop press without issue. There is just enough lower wishbone around balljoint flange to engage a snug fitting tube spacer. I used a short piece of water pipe split lengthwise and then sprung open so as to fit very snugly around flange. Socket on back of balljoint and came straight out.
My jig secures to sway bar link mounting bolt position with angled spacer mated to angled wishbone end and ring on top to locate balljoint C clamp press. Fitting tube on balljoint flange and press away. Shop press may work ok but you will need more than two hands.
I did leave balljoints in freezer until ready to fit.
