lower control arms
Received 2,193 Likes
sometimes I am amazed at the number of people that dont know how to FIX suspensions and want to modify stuff to fix something that needs to be replaced with new parts. ie wornout upper shock mounts. this has come up several times on here and good job to ya'll that helped to FIX the problem correctly. on a side note, thos offset bushings/bolts etc are to fix frame damaged cars or to allow proper alignements to be accomplished once you start lowering ride height and or useing the car on track days and want to dial in more camber and less caster
RaceDiagnostics
09-13-2015 02:22 AM
