lower front shock bushings
Received 2,191 Likes
I agree on the squeaks, but I do not agree with the rest. I switched to Poly on my vette and the ride was not that much more harsh, but the suspension handled much better and the bushings still held up great after 100k miles, my originals were shot after 80k miles and my jags are shot after 70k miles.
Youll get no arguements here. But there are compromises always made, and reason that OEMs use what they use. Jaguar are not modded like Vettes and no where even on the same planet are they comparable with aftermarket support
We as enthusiast tend to be more tolerant of certain aspects or compromises than others.....
one test with the poly sway bar bushings (little squeaking) and yes, although stiffer, it carried alot of vibration to the wheel...that was enough of a trial run for this casual driver, who bought a comfortable touring car, not a street racer/performer. I went back to OEM rubber.
I was not trying to stir up and arguments, just stating my opinion and wondering why I could not find some on the market.
randyb, go to the Powerflex web site. I have found their poly bushings to be exceptionally well made/finished. I have installed the front upper control arm poly bushings and the rear frame poly bushings. Handling is improved with not much loss in perceived ride quality. Some have reported that polly busings "squeak" but I have not found that to be the case with the poly bushings on my 2005 XKR coupe.
Hope this is helpful.
Tim V.
Tim V.
Tim V.
Tim V.
But they do not seem to have the lower shock bushing, but when I replace the rest of the suspension, I will use their poly bushings.
RedCarrera et al.
here are some links for delrin and other bushings and bearings.
May save you some $$$. Bronze can be lubed, acetal, delrin, and nylon, check the physical properties. Pretty darn close.
Semper Fi Mac,
Bill
McMaster-Carr
McMaster-Carr
McMaster-Carr
McMaster-Carr
Semper Fi Mac,
Bill
McMaster-Carr
McMaster-Carr
McMaster-Carr
McMaster-Carr
Thanks Bill... McMaster happens to be where I purchase most of my stock. Unfortunately I already purchased a pair of shock bushings from British Auto Parts, but at least I have a sample for turning a set out of delrin. PS - bought TWO stock bushings and paid 40% of the dealer cost for ONE.
KarimPA
09-12-2015 08:15 AM
Tar
09-06-2015 11:24 AM
