Lower timing chain noise
Skid Mark (02-21-2011)
Yes the Primaries can cause an engine rattle. They don't fail as often as the secondaries, but I have replaced failed/damaged lowers and the curved tensioner blades that rattled as a result.
TSB for you
The warranty times are NOT real world, but that was all Jaguar was willing to pay for the engineering mistake.
bob gauff
TSB for you
bob gauff
Thanks guys. I talked to my indy tech today and he said because the noise goes away after engine warm up, it could be a partially blocked oil port for the tensioner(s). He reccomended a lighter weight oil to see if it went away. I'll take it in tomorrow so they can take a listen w/the stethoscope.
innzane
09-02-2015 10:08 AM
