Lowering only the rear of an xkr?
I've noticed that my newly acquired 2003 xkr convt. as well as others I've seen have a very noticeable rake. The rear end of the car sits quite a bit higher than the front of the car.
I've learned that H & R springs are not made to handle the extra weight
of the convt. So, they're a non starter.
The lowering springs from Mina have gotten positive reviews here, but,
apparently, once lowered, the inside of the front tires seem to wear a little quicker, especially if the fellow doing the alignment lacks expertise.
So, I'm wondering, what do you think if only the rear springs from Mina
were installed, to get a more level and balanced look to the car?
How do you think this would affect handling?
I found the same problem with mine. It reminds me of the newer Mustangs with their butt in the air. I had lowered my Contour SVT and didn't want to run into the same clearence issues. I found a guy with a stock set from the Silverstone that he had replaced with Mina's. He said the ride height was the same with both springs. So I installed only the rears. I have no driving or handling probems and haven't notices any wear problems.
edtexas (11-29-2010)
The Silverstone rear springs lowered my rearend about .75". The shop that put them in did an alignment (toe-in) but wanted to let the springs settle in before setting the camber. This was only noted to me after I asked to see the alignment sheet and there where red number on it. If it were in spec's they would have been all green. After a few weeks I took it back to have them finish the alignment only to find out they wanted to charge me another $190 for another alignment plus $300 to install the shims ($75 each). I opted out. The tire wear seems to be fine, but having the shims installed is on my to-do list.
I have lowered many....many...XKs and have never once had to adjust the alignment, OK that is a bit of a lie as one car came in with back inner tyre wear which meant he had bad tracking to start off with, so adjusted accordingly, but, on a normally set up car I have never had to do this.
The only time I think it is worth having done is if you have had polybushes fitted.
Just had a thought......OK I might contradict myself a little here but if you lower your car 40mm (I never recommend going that low), then yes you will need as a minimum a camber check
Wolfy
05-28-2024 08:06 AM
