LSI Convertible Top Hydraulic Kit
I installed the LSI kit about 3 months ago on my 2003 XK8. It is working without any problems. The only problem I had with the installation was that the T30 plug near the manual valve must have been put in by a gorilla. I got it out but I dont know how I did it without breaking something!!
My reason for posting this note is to ask if anyone is aware of people having hose failures after installing the kit?
I am hoping for a deafening silence!!!!
Doug
Did you get the pump back from the dealer? I have been attached at the hip to the top hydraulics issues since that was the reason I was able to get into a XK8 so cheap to begin with. I do not think I have ever seen a documented pump failure in the past 3 years. I would really like to understand the problem with your pump.
I have seen pumps replaced, under warranty, simply because the manual by-pass valve was not closed.
![Thumbs down](https://www.jaguarforums.com/forum/images/icons/icon13.gif)
When I installed the LSI kit on my original pump, it was really pretty smooth except for the interference at the T30 plug due to nearby fitting. I just did the install on the new pump that the dealer installed and you are correct. Getting the T30 plug out required more elbow grease. What was worse was that the nearby fitting on this pump was somehow creating more interference making it tougher to get hose #1 attached.
Doug
Doug
Several others commented on the conflict with the elbow fitting next to the T30 plug opening. I had the same issue and stopped my installation as I couldn't move the elbow fitting. What are some of the workarounds, or how did you finally get Hose #1 in place? Thanks in advance - I think about the hose blowing every time I close the top! DaleD
Loosen the hose on the elbow since it is the collar on the hose that is creating the interference. Don't completely remove the hose though. Once the collar is backed off some you should be able to get to the T30 plug. This way you don't have to move the elbow. Then simply tighten the hose back on the elbow once the new hose is in place of the T30 plug.
Doug
My son installed my valve, he is used to working on diesel engines so the required torque to remove the T30 plug and move the elbow wasn't a problem for him. Our only concern was breaking something in the process. He ended up rotating the elbow within the range alllowed by the other fitting. Tightening the elbow moved it a little beyound it's original position.
When I tried tightening the elbow on the second pump I lacked the proper tool/leverage to accomplish this. Also, I was afraid that if I had been able to come up with a way to further tighten that I would end up breaking something in the process. I was lucky that the high spots on the hose #1 fitting did not overly rub against the elbow as I was tightening the fitting but the next thing I would have tried was to take a file or dremel and carve away a bit of the elbow to allow for more clearance.
Doug
Doug
If you look at my install on my page you will see a hammer in the background. I used this hammer to tap the fitting to turn it a little. NO I AM NOT TELLING YOU TO DO THIS AND I RECOMMEND AGAINST IT but this is what I did to turn the fitting. I did notice that all the fittings were tight and the T30 was a bit difficult to remove but it was not imposable. I think they used a lock-tight on all the pump connections and that is what made it so difficult.
Doug, did you get the pump?
Hi Gus--I will send a follow-up email to the service rep at the dealer to see if my old pump is still around or if they needed to send it to Jaguar.
Dale--the job is not as difficult as it sounds. There are a few frustrating steps (removing/reinstalling the pump if you have a tall accessory rack is a small challenge as is disconnecting the black/white electrical connector) but the rest is really pretty straightforward. If you have your tech do it you should at least be there watching.
Doug
Doug
Don't be at all shy about installing it yourself; it's not difficult when you follow Gus's great instructions and photos.
I too used the "hammer technique" to gently move the right-angle fitting ever so slightly, with no problems (one or two light taps did it; your mileage may vary). I would recommend this over filing or altering the fitting in any way. Why risk making a part less strong rather than just a smidgen tighter?
The biggest challenge, if there was one, was deciding whether to buy a star bit that fit my socket wrench or a complete "key" set. I'm glad I got the socket wrench style because the other would not have worked as well to remove the pump from my tall accessory rack in tight quarters. I also used my U-joint socket swivel in combo with the star socket and it worked great with the uninstall/install of the pump assembly.
No worries! Good luck!
I installed the LSI valve and the CGR lines about 3 weeks ago. No problems.
I thought I'd weigh in on the install. I have a 2003 XKR with about 76,000 miles.
By tightening the 90 degree fitting near the plug I was able to get the #1 hose installed. I couldn't budge the fitting with a wrench but a few delicate taps with a hammer moved it just enough to where I was able to install the hose.
I installed the valve before the hoses as I didn't want to manually lower the top during the hose install process.
After I routed the lines all the way back to the trunk I found that I had to remove the #1 hose and also the t-handle for the manual pressure relief value to install the 90 degree fittings that came with and are required for installing the hose set.
Everything fit back together and is working without issues. I didn't install the 90 degree fittings nearly as tight as they were on removal.
