I have the same lug nuts here. So I would think they are OEM lug nuts. I'm thinking of replacing these as the loose cap, I suspect, will eventually work loose from the threads. Fellow Forum member Rothwell has looked at many different solid lug nuts for his newly refurbished rims. If you're going down this route, I would check his threads on this forum. He's done some lovely under-stated upgrades to his car to make it more user friendly.
Yeah those are the horrible OEM lugs. I have always replaced them with solid ones ever since I had one of the outer covers start spinning on the lug inside. Happened on my first Jaguar S-Type about 15 years ago. Plus the outer caps being loose fitting would create a chatter that I could hear at low speeds, particularly in parking garages.
