Mafs
Two biggest failures in my experience (with MAFs from various manufacturers) has been dirt on the sensor and broken leads inside the MAF, between the connectors and the board. That's not to say a component couldn't fail but I'd bet that if someone is remanufacturing them it would be because of something simple or the OE has assembled the MAF into a huge housing that doesn't go bad yet adds siginificant expense to the part (consider the ABS controller and throttle body.)
New MAFS range from $250 to $400, Used from $125 to $200 (90day to 6mo exchange) and a remanufactured is from $100 to $175.
I wanted to know before I spend the money if the remanufactured is an option. It seems to me that they are replacing the electronics and testing them to meet the manufactures suggested values but I guess it is all in where you purchase it. I have no use for anything that does not work and get a little annoyed when its life expectancy is less than desired.
Steve you got yours from Advance Auto? What was the cost then?
jimforrest (uk)
02-28-2019 06:42 PM
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
xjrjag
09-27-2015 01:53 AM
