Manc
Old 02-27-2016, 05:58 PM
Manc's Avatar
Default Manc
I have a 2002 xk8 that will not start. When i turn the key, it makes a whirring noise but does not engage the engine.....any ideas please.
Old 02-27-2016, 06:02 PM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
You need a new starter.
Old 02-27-2016, 06:14 PM
Manc's Avatar
Default Starter
Thank you very much Vern. I was confused because when i parked it, it was ok then the following it would not start...... No warning
Old 02-27-2016, 06:29 PM
RJ237's Avatar
Received 2,803 Likes on 2,237 Posts
Banging on the starter may free up the gear, but that's only a temporary fix. There are other things that quit suddenly, like fuel pumps.
Old 02-28-2016, 01:13 AM
oyster's Avatar
Hi.
Are you absolutely sure the engine is not turning? Loss of compression due to what is called bore wash sounds sounds just like the starter not engaging.
Check at the front of the engine for rotation while cranking.
WhiteTardis
05-07-2020 11:09 AM
mitcharon
03-20-2016 11:57 AM
o2manyfish
03-05-2016 10:44 PM
Amelorn
02-29-2016 04:22 PM
mitcharon
02-24-2016 05:52 AM
Quick Reply: Manc
