manual backrest adjustment ?
Is there any way to manually adjust the seat backrest by turning the motor by hand? The switch does not work...only clicks. If so, what is the best way to go about accessing it? Got a few days off and thought I may try to tackle this problem.
Thanks and Merry Christmas!
If you have a backrest that does not respond, it is highly likely the seat controller module that is the problem This is the most common failure mode. You can verify this by swapping driver and passenger modules.
Search 'seat module'. There are several threads on this problem, which occurs when a printed circuit trace at the edge of the module breaks due to abrasion from the case and atmospheric exposure. It can be repaired with some basic soldering skill and a steady hand. Another member recently used a conductive ink pen from Radio Shack with good results.
aholbro1
08-05-2021 05:02 AM
al_roethlisberger
09-21-2015 08:07 PM
