The key is mechanical, i suggest opening the trunk then spraying the lock opening with wd-40 and the move the key back and forth to free up the lock. With the trunk open there is no tension on the mechanism. Once the key turns 90 degrees close the trunk and open with the key. Once freed up try to remember once a month to open the trunk with the key.
I don't have this problem but man, are you guys ever full of it.....information that is!!! You never cease to amaze me how helpful this forum is. I learned something new again today. Keep up the great work. Thanks for this one Graham. TM
Tried to work on the locks today None of the 3 keys will rotate the lock cylinder
tried prying the egg shaped cam on cylinder and no movement. I don’t see any issues with the connecting cable
Loosened mounting bolts in case there was some binding
The inside the trunk emergency release seems OK
I have been spraying the key hole with PB blaster penetrating oil but no luck
To be sure I wasn’t trying to open trunk with valet key all 3 keys open and close glove box
All looks clean and shiny in there, but either the cable is stuck, or the lock cylinder is.
Judging by GGG's diagram, it looks like the cable can be separated from the actuator by lifting the outer cable upwards then unhooking it from the nylon cam. If not, then remove the circlip and pull the cam off the cylinder.
If the lock still won't rotate, then the cylinder is stuck or, possibly, key and lock don't match?
Does the key work in the doors?? Maybe the ignition switch was changed and that's the only one you have, meaning all 3 are the same. Just a thought. TM
OK I think I fixed it. I removed the lock to be sure it wasn’t a cable problem. When I removed the lock I also discover the roll pin in the picture. Without the roll pin the lock cylinder rotates. I believe the roll pin’s function is the limit the penetration of the valet key. I don’t have a valet key so no issue
reassembled without the roll pin and everything seems to work fine.
many thanks to those of you who contributed. Could not have done it without you
UPDATE. I believe I am in error and the roller pin goes into the slot Horizontally on the key cylinder. Not sure of the function but it works without it.
I’ll do another R&R to investigate. Probably use the key every 2 years when I have a dead battery
2003 xk8 lid lock assembly
Reason: Added comment about pin location
Couldn't remember the last time I opened the trunk of my wife's 2006 XK8 with the key. Just tried it and the trunk opened perfectly. That powdered graphite treatment a couple of times per year tends to keep the locks functioning smoothly....
The TSB shows that the locking pin is installed between lock cylinder and housing. With pin installed cylinder won’t rotate. Removed pin and lock works fine. Since key is used so infrequently I will live with it but I keep wondering what is wrong
