Map Light/Homelink Console
It appears as though the adhesive qualities of my map light/garage remote console at the windshield top have given way and are hanging....
Has anyone developed a successful fix or guidance on this? I can experiment but if there is a known way I'm open to suggestions.
Thanks!
Thanks!
Received 4,339 Likes
coupe or convertible?? If convertible - there is a plastic bracket mounted to the frame above the windshield and compression clips on the console slide through holes in the bracket to keep in place - SNG Barratt's
SNG Barratt - The Ultimate Jaguar Parts Specialist
I agree with Sklimii,
The black plastic piece that accepts the clips from the dome light unit had broken on mine. I removed the plastic piece, and glued it back together (I had all the pieces)
After it dried, I refastened the black receiving piece, and gently pressed the unit's clips back into it. All is well.
Jaguar2373 (12-23-2022)
