Map Lights 1997 XK8
Ok got it. Mine are individually switched, push to light. What to push? I never use them, I forget if its a switch or the bulb assembly. Based on the bulb assembly yelling at me last week as I pressed the pod in place, there's a off/on switch up there. Look around?
Btw they are not designed to illuminate if you turn the dimmer switch to click position.
John
John
Jaguar2373 (08-25-2022)
