Max ok coolant temp? Danger temp?
I have a system for my 2000 XK8 Coupe that allows setting alarms for configurable thresholds on various ODBII readings.
I've had two coolant related fixes recently, water pump and leaking thermostat housing, and decided I needed to monitor the coolant temp more carefully than I have been while testing coolant-related fixes.
So my question is, what temperature should I set an alarm at?
Bonus question: are there any other readings I should set alarms for?
Thanks!
"You know you drive Jaguar when... you are compelled to wash a car you cannot drive."
Thanks!
baskervillema
10-01-2015 06:43 PM
