Metal thermostat housing v Plastic housing
Old 09-30-2011, 01:55 PM
Jochem00's Avatar
The older XKR series without navigation but with the Mercedes gear box will be in demand in 30 years from now.
Old 09-30-2011, 02:04 PM
shw57's Avatar
Gus -- VERY HELPFUL LINK!!! I love this website!
This appears to be a rather cumbersome repair!
I have purchased the housing.
Now to see if I have the guts to try it myself!
Old 09-30-2011, 02:16 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
If I can do it you can as well just take your time.
shw57 (09-30-2011)
Old 09-30-2011, 02:52 PM
shw57's Avatar
Gus -- I see that you are the true author of that PDF documentation! Very Well Done!
I especially like the tip about the open end wrench that you customized for this repair.
I have an 01 Vanden Plas that has more front-end room that may not require my having to remove the fan housing, etc.
I think I can just remove the front hoses to gain full access.
I do have a new thermostat from previous work done.
Is it difficult to reassemble into the new housing?
I have no idea what I will be getting "into".
Any other tips?
-- Very grateful to you and your experience!
Gus (09-30-2011)
Old 09-30-2011, 03:29 PM
Gus's Avatar
Gus
Gus is offline
It is not difficult at all. The thermostat will only go in one way but to be sure for your satisfaction attempt to put it in both ways and you will see. As for the gasket they fit directly into a channel just be sure not to pinch them as you install them and you will be fine.
Old 09-30-2011, 09:59 PM
mike66's Avatar
Jochem I agree. The nav became obsolete <5 yrs after it came out. The R with the mercedes gearbox seems like a winner, athough any of these cars should be desirable 20+ years from now. For the thermostat, make sure the bleed pin is at 12:00. The pin or ball can be removed according to some and that's what I did. Don't know if it makes any difference.
Poet
06-07-2019 07:54 PM
vwbusbits
10-13-2015 03:43 AM
multistrada74
10-08-2015 08:58 AM
hoodun
09-28-2015 01:08 AM
BlacXJRcat
09-25-2015 06:43 PM
Quick Reply: Metal thermostat housing v Plastic housing
