Mina Gallery exhaust
When i removed the two small mufflers in front of the rear axles and replaced the over the axle crushed pipes with round ones, keeping the rear boxes, i did see a slight HP increase on my friend's dyno. Not enough to matter, but a fun thing to note.
When i removed the two small mufflers in front of the rear axles and replaced the over the axle crushed pipes with round ones, keeping the rear boxes, i did see a slight HP increase on my friend's dyno. Not enough to matter, but a fun thing to note.[/QUOTE]
From what I have read here that is the route to take, although I haven't pulled the trigger yet. Removing the rears resulting in droning at steady speeds. Wouldn't be cool. TM
I bought the Mina exhaust system and air intake tube for my 1997 XK8 and it sounds great, especially when you put your foot into it. It has the straight pipe to the 1 can at the back on each side and duel pipes running back from there, no tips.
