Mina Gallery Shipping?
I agree with the person who wrote that you need to choose the delivery that will deliver your goods safely. Especially if it concerns some fragile parts, according to the type of part for the car, it's very important. My father ordered replacement parts for himself in his car about a year ago, and they came to him crumpled and thus absolutely unusable. Since then, I have been cautious about ordering something myself and now I try to buy something offline at once so that there would not be the same cases. If it still comes to delivery, then for now, I order only using china post ems tracking. Of course, I would be distraught if my parcel was damaged, but thank God this has not happened to me yet
Kuddlesworth,
I have the same model year as you and with the Adamesh 2 stage fitted. I was equally apprehensive but eventually went for the Mina pipe for it's simplicity and aesthetics - which are perhaps not the best reasons!. But after 1000miles, here are the pro's and cons as I see them:
- It looks great and much better than OEM - especially if you show your car.
- The supercharger whine is a little more noticeable and I find this is a really cool feature !
- There is a slight but noticeable increase in throttle response throughout the rev.range.
- After a warm-up run of ~10miles, the surface temp of the Mina Ali pipe is an average of 8 degrees hotter than the OEM plastic . This is based upon 5 independent measurements of both versions using a Pyrometer.. The hotter pipe probably increases the Air intake temp which is supposedly detrimental to performance but I don't notice it and I surmise that the intercoolers manage the increase in temperature delta. Also interesting is that the Mina cools down quicker than the OEM when left at tick-over with the bonnet up.
- I haven't measured the fuel economy and refuse to do so - Owners of V8 Superchargers are supposed to be beyond such trivial things! But i would suggest that it does reduce economy because the slight increase in throttle response cannot be for free. Maybe the ECU increases fuel supply to match the slight increase in measured air - I simply don't know for sure but it is a common sense approach.
- Definitely hold on to your old OEM Air pipe so you can revert back to standard spec as it might help to maintain sale value in the future.
Hope this helps.
Kuddlesworth,
Hope this helps.
Yes, any thermal insulation or heat shield would do the job.
There are some points that make the Mina superior.
The Mina has fixed diameter throughout it's length and this supports more 'Lamina flow'. In lamina flow, only the air layer in contact with pipe wall is heated which means a smaller volume of intake air is affected.
In retrospect, the OEM plastic pipe changes cross-section, has sharper bends and the inner surface has many edges. This creates turbulent flow which means more air is in contact with the pipe wall and a higher volume is heated.
This may be why I do not experience any loss of overall performance with the Mina fitted.
Kuddlesworth,
The standard XKR OEM intake pipes for 4.0 and 4.2 are actually engineering masterpieces (they differ). My friend did his Masters dissertation on them!
Jaguar NVH engineers developed this pipe to improve intake resonant performance and reduce acoustic emissions from the Supercharger (which spins 5% faster in our 4.2 Ltr than the 4.0 Ltr). The Supercharger emits it's loudest whine when drawing up to 410 Ltr/sec airflow and the marketeers considered this whine unsuitable for Jaguar customers [Nowadays, a supercharger whine is a considered feature on Mustangs, BMW's and Audi's]. The 'noise' is addressed by 7off silencers installed along the pipe. The silencers are the 'blocked off pipes' that you mention and appear to have no function. Each are of different length and volume to attenuate specific audible frequencies within the rev range. In it's day, it was the quietest M112 Supercharger installation on the market.
The corrugated section is to suppress passive vibration in the MAF sensor, Air box and its fasteners.
#28
Kuddlesworth,
It would be interesting to know if anyone has had MAF sensor failure with the Mina fitted.I couldn't find any reference to it during searches.
Mina do provide a rubber elbow joint for the Throttle body connection and this absorbs some vibration.
Other factors can exacerbate the vibration transmitted such as a detached instrumount beneath the air box, leaked engine mounts or de-bonded Vee mounts.
XKR's also have a small solenoid within the Air box that is at risk of vibration damage alas there is no record of it.
#30
I did consider it as it may fatigue over time because the filament within the MAF is very delicate.
