Misfire help
Before you begin to speculate and long before you even think about throwing parts at it, have the codes read. Post the actual codes back here - not the descriptions anyone who reads them tells you they mean.
Please add 'location' and 'vehicle details' to your profile. It helps everyone to give relevant advice.
I concur. Clean your mass air flow sensor first. You can purchase a spray can of mass air flow sensor cleaner at any chain auto parts store for about six bucks. Two screws (some cars have Phillips screws, some cars have Torx screws) hold the sensor on. Once the screws are removed, unplug the sensor's electronic harness carefully, take the sensor outside, and give the inner element several thorough sprays from the sensor cleaner can. DO NOT attempt to wipe any part of the sensor dry. Wait a couple of minutes and repeat. Then set the sensor aside and allow it to air-dry for 30 minutes or so. Re-install it, clear your codes, and drive the car to see if you fixed your problem....
If the trouble codes return, it may be time for a new sensor....
Norri
19
09-28-2015 08:43 AM
