Mixing top fluid oem & 11S
The UNIVIS fluid is a yellow color and I guess you can mix them but a flush&fill is better.
I have done many conversions when I worked at the dealer.
You can 'suck-out' as much as you can and then add the Pentosin?? That will dilute as much as possible. You could cycle the top several times to mix the fluids and then empty the reservoir again. Top up the level again with Pentosin and that might get the top back to normal.
The lines for the top latch are LONG and SMALL DIAMETER so you might not get all the fluid changed in those lines.
TSB for the way we were to perform the task 'back-in-the-day'.
bob
bob
