moisture inside headlight compartment
Would like to get rid of the moisture that has collected inside one of my headlight enclosure. Not sure HOW to remove the headlight bulb or? to gain access for a blow-drier... Any ideas on how a novice mechanic can accomplish it without breaking something (smile)?
XKRoo (04-06-2013)
Common problem: drill 1 or 2 8mm vent holes in the large transparent plastic cover on top of the headlight housing and then simply warm the glass from the outside with the hair dryer until the water has gone. The two holes should prevent 95% of the problem reoccurring in the future.
XKRoo (04-06-2013)
XKRoo,
Since I bought my 2002 XKR about 3 years ago, I have always had a lot of moisture in the driver's side headlight but not passenger side til about a month ago. It then started on passenger side as well. Twice, I took a hair dryer, heated up the glass until the moisture disappeared, covered my car with its weatherproof cover for the night, only to find that by 6am the next morning, moisture had returned. Last Saturday, I went out to my car in the morning to find both headlights completely dry for the first time ever! It's been that way for the last 3 days, we had rain on Sunday (briefly), and still everything is dry. I have no idea what changed as I have made no alterations, holes. added silica gel or anything else. Magic!
XKRoo (04-06-2013)
My 98 developed the same problem, I removed the plastic covers, turned the lights on and went for a drive, a few miles later, no condensation. I haven't bothered to put the covers back on, but when I see condensation I just run the lights. No dust inside yet, but plan to drill and install easily removed plugs.
XKRoo (04-06-2013)
