More Power!!!
What makes you think you have lost power?
Good start is always to ensure everything is in tip top shape, i.e. gaskabel adjustment to basic stuff like air filter, plugs, possibly an emission test, checking obdii parameters etc. all to ensure the engine is running properly as it should.
Then you could do a base dyno run to establish the current power levels, as all might already be ok.
Last pending the above costs, you might still have some left from the $300 which could be enough for a K&N panel filter, though you will never feel the difference though.
OK, are we going to get into that throttle cable adjustment thing again? Is it "extra power", or "restore original power"? I checked mine, and it did not require adjustment. However, when I bought it, the previous owner had some rather thick floor mats in it and the one on the driver's side went up under the throttle pedal and stopped it from going all the way to the bottom.
+1 Lots of good advice above. Spend first on getting her working perfectly.
If then you are still not satisfied, there are some options, especially with an 'R', but big gains do not come cheap.
Also, keep in mind that these cars are designed to be at their best power-wise accelerating at high speeds, they are not particularly fast off the line.
Not particularly fast off the line? It's faster than a porshe 911 and the same as a top end BMW M3. So quick enough. But thanks everyone for all the advice. It was going to the dealer next week, but I'm away working for a couple months, so will let you all know early summer if i notice any improvements after the work.
Mike
Mike
Mike
Mike
I'll second Mike (White XKR). While it is fast off the line, could be faster. The efforts of the car aren't channeled in 0-60 (0-98/100) times.
Do as Avos said, check all the piddly little basic things before you attempt to exponentially increase your HP. Do some quick searching through the pages in this forum and the Engine Tech one and you will see some ideas/projects/options that are out there and in most cases associated costs.
The one option you may have is getting in contact with XKRacer from this forum. Do a search for some of his threads.
That does work, and gives fair bang for the buck, to a point...but the intercooler temperatures rise quickly with the extra boost...reducing performance back down again...which leads you to wanting a more expensive intercooling upgrades or killer chiller, etc.
