Most annoying thing about your XKR
#81
rise low beams
In my adventures in rebuilding my XKR, I found out you can rise the low beams electrically. Modify the plastic thingi behind the low beam adjuster knob so you can turn it to a virtual "-1" instead of 0..3 will rise the beams more.
Remember to put it at 0 again when going for the inspection.
Regards
#83
No behind the adjuster knob.
there is a potentiometer there that can be rotated much higher than zero if the knob is removed. i know as i have removed the whole panel and relocated the adjuster potentiometer.
(A) in the image
XK8 instruction manual clip
#84
i bought a really deep, well made plastic dual cupholder for my XKR. it is wedged between the console and passenger seat, and slips out easily and is less than $8.00
https://www.amazon.com/TSI-Products-.../dp/B0009N4F6I
i "broke" the original XKR cupholder as it was useless, and missing one spring... and now use that to hold my phone while driving
#88
looked at it on amazon... seems like a cool fix, but does it cover some of the passenger seat?
or please post a pic
Many Thanks
Andy
#90
Wide_Tyres_2 (04-04-2017)
#91
#92
#93
#94
Lack of a front license plate bracket. Constantly paranoid that I will be ticketed and have to prove to a judge that I have complied by mutilating my front bumper with a Jed Clampett, chewing gum/bailing wire installation.
Never understand how with 26 states requiring a front plate, all vehicles don't have them as standard?!
#95
ObscureDave (04-04-2017)
#96
#97
Amen!
I hear you! Personally, I can convince myself that either with or without can look okay. But if a front plate is present I want it to look "factory"; that the placement was aesthetically planned.
#98
Hmmmm!
I drilled a couple of holes in the plate and mounted low with a course tread screw in the holes that were there from the original plate holder and then with a couple of chrome screw caps finished...bent the plate to contour the bumber... done and legal as it is a $170 fine here in BC
#99
ObscureDave (04-05-2017)
