Mountain
Hello XK8 fans,
Is there a measurement for the free length of the front coil springs in the 1997 XK8 convertible.
The front end looks a bit low and tyres sometimes touch the inner guard liner.
Shocks and spring mounts are in good condition. I suspect springs need a reset.
Australia
Australia
Hello XK8 fans,
Australia
Australia
I used some aftermarket mounts which proved to be useless and ended up getting my original ones rebuilt by @baxtor . These improved the height considerably but I also bought new springs as I discovered that the original ones had sagged quite a bit. I don't recall the exact difference in spring length between old and new but I do know it was noticeable. I now have my front riding close to the recommended height.
As an after thought, do you know if a previous owner has perhaps fitted lowering springs at some time in the past?
I'm in Australia as well by the way.
Phil
Dr. D (06-21-2024)
Phil
Thanks for the reply. Where did you buy the new springs. I am told they are no longer available as a Jaguar part.
I can get a set ex Sydney from a vehicle being wrecked but that is hit and miss.
To get them remade or reset we need to know the free length, load to compress to a specific length, and material spec, and of course somebody with the skill to do it. Its probably a lost art.
I will try sourcing from the UK .
Hi Graham. After much research I ended up buying springs from Berkshire Jaguar in the UK. Not the cheapest option, I'm sure but even with postage and a generally unfavourable exchange rate, it was a good buy. The springs are German made and good quality. They and Baxtor's shock mount rebuild certainly gave me back the correct ride height.
Phil
Phil
