My first restricted performance. Yippee!
Ok, not really a cause for celebration.
02 XKR. Pulled the codes and have the following:
P0172 - rich condition
P0175 - rich condition
P0101 - Mass air flow A circuit range performance
P1111 - ECM internal error
Unrelated, by since last evening the transmission shifts are delaying to higher rpms, similar to what it would do in sport mode, but it isn't.
Suggestions welcome!
Definitely focus on the air flow meter. It's probably toast, but you can try and clean it. It is by the air box. 2 screws and a connector and it is out. There is air flow meter cleaner at the parts store (a spray). Folks ofter repeat that other similar sprays (carb cleaner, etc.) should not be used for this, so resist the urge to get something "already in the garage". This spray is known to improve mileage, etc, but I have yet to see this cleaning actually clear a code for more than a couple of trips.
The alternative is to search for a new sensor. The best is to locate the DENSO number, and search with that (eBay, Amazon, Rockauto, etc.). Expect $100. Do this research with care, there are LOTS of similar looking parts with lots of promises of compatibility, some insanely cheap. These parts all fit, but somehow the signal is not the same. On the flip side, the right part with the right DENSO number will likely be suitable for lots of other cars as well.
Best of luck, keep us posted.
Magic DOES play an important role in the behaviour of this wonderful, sensitive, hypochondriac car. I hold that there are many occasions when those glitches that so magically appear also magically disappear. A quick turn off of the ignition, a code reader clear, and - abracadabra! - all is well once more.
Until the next time.
zray (08-26-2018)
