Is my gearbox dying??
Hi all, I found a new problem with my 97 XK8 yesterday which I would appreciate some thoughts on; when pulling away from standing the engine revved but the the gearbox did not engage. This happened 3-4 times towards the end of a 2hr drive, I tried changing re-selecting D but this did not seem to work instead the gearbox seemed to re-engage after a few seconds of revving. Other than this the gearbox seems to change well. I ran the IDS software this morning but found no error codes.
I assume you have the ZF5HP24 gearbox, and no drive into 1st is a classic sign of A Drum failure. However in your case, you did a drain and fill only 4000miles ago.
And in your case, your problem only happens when car is hot. I would guess you have bad Spec ATF and/or under or overfilled it.
Does it happen when car is level or on an incline?
Overfilling is just as bad as under. If overfilled, the ATF foams and heats up, leading to gear slippage.
Johnken (08-01-2020)
To best of my knowledge it is the ZF5HP24 gearbox. It has happened on both a steep hill start and a level car park. I have had no issues since the oil was changed (carried out by my local Jag indy, who I seem to recall checked the level more than once). As I live in a hilly area with very few 'highways' the car has probably done a lot of gear changes in those 4000 miles, so my gut feeling is any issue from the oil change would of arose sooner?
Received 2,400 Likes
Bonsoir,
Yes, you do have the 5HP24.
I would check with your indy that he did use a trans fluid that meets the LT71141 spec, and that the filter was also replaced.
It could be the beginning of 'A' drum failure, but do the easy stuff first:- does drive engage with a thump? Is the fluid level correct?
+1 on checking with the mechanic what ATF he used. Zero dollar check.
If the ATF is overfilled, it’ll heat up and gradually, over time, lose its lubricating properties. So the 4000mile is actually a good sign!
See what the mechanic says when he did the drain and refill. Hope he put a new filter in too.
Worst case scenario is that the A Drum is bust and that’s a professional tranny rebuild job! Not many home DIY shade tree mechanics can do it, but it has been done by some expert Forum members here. Also there’s an upgraded A Drum available.
